Departure and comfort not working
Ahhh the cold season is upon us and it's time to start monitoring this thread again, I'm curious if any updates we received recently have fixed the heated steering wheel failure after the departure time has completed and the first drive cycle has commenced, anyone tried this out lately?
I haven't used preconditioning all spring & summer, but might go back to the routine when deep winter set's in.
Strangatang
Dan
NJ
2022 Ford Lightning
I turned off preconditioning and made sure all temp settings were off and yet my truck keeps on warming up everyday. Nice during the summer to have a warmed seat and steering wheelโ€ฆ.
Have you verified that itโ€™s off in the truck and not just FordPass?
I need to shut it off in 2 different places?
The setting in the truck is what controls it. Sometimes, FordPass settings donโ€™t get transferred to the truck. I only set departure times in the truck - FP isnโ€™t reliable.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi, Dan. I can take a closer look into your Lightning comfort concerns if you'd like. Can you send us a private message with your VIN and the dealership name/location? To send a private message, just click on our username and select "Start Conversation".
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
I tried it todayโ€ฆand it WORKED! first time ever. Had heated steering wheel all the way home from work after preconditioning.
luebri
Neenah, WI
Not for me. Still no heated steering wheel when using departure times. Same issue as last year and Iโ€™m fairly current on updates. Iโ€™m a 8/15/22 build ER lariat.
the setting of the departure time ~20 minute early than actual departure isnโ€™t even working so far.
I'm going to test ontime departure time, if that fails, I'll try a 25 minute advanced time on Wednesday.
Both will be run while unplugged.
This mornings test was a success, set for 0800 hrs departure, actually got in the truck around 0805 the truck remained on standby (Push to Start) message on drivers cluster, the cabin, seat and steering wheel was warm, fired her up and away we went, the wheel remain on and warm the whole drive.
This positive result, negates the anticipated 25 minute offset test on Wednesday morning
I will do another "on-time" test but with the truck plugged into the EVSE, getting the energy for pre-conditioning from the grid instead of the truck battery. I'm hoping it behaves the same as today, warm everything when ready to go.
I've been using departure to cool the truck when I leave work (still high 90's here). Haven't had a problem with it (just me sometimes turning departure off and forgetting to turn it back on).
luebri
Neenah, WI
Weird, I did the same test while plugged in. I had it unplugged and then plugged in at 0705. I had my departure set for 0730. I can see that I sucked ~1kwh of energy in 30 minutes for the precondition. My heated steering wheel was set to on, but was not warm at all, and never gave me control during the drive. The rest of the cabin and my seat was warm as desired.
I will adjust to 0700 departure tomorrow, while plugged in and see how it fairs, my actual departure will be 0730.
flyin525
Richard
Youngsville, NC
Well I tried it again today, after it worked fine yesterday, and the steering heat didn't work, so I'm at a loss. It also didn't work when I turned it on manually, just like it used to do.
This morning the truck was on the EVSE [FCSP]
No warm steering wheel, everything else was great, cabin and seats toasty warm.
If it's within ~20 minutes after scheduled departure time the manual switching of heated wheel remains inhibited, only after the truck has been shut off beyond that time frame does it resume working, just like last season. I guess the fix for this is still pending for the future.
Fordpass Status-----------------
Ford F-150 Lightning Departure and comfort not working 1697634198643
Emporia measured start 0741 for 0800 departure
Snap shot is 0806 just before I unplugged @0808
Ford F-150 Lightning Departure and comfort not working 1697634387454
Total energy 2.07 kWh or 53 cents to warm up.
{4 miles of range conserved from the battery}
Ford F-150 Lightning Departure and comfort not working 1697634551891
derm
Lance
Chesapeake VA
2023F-150 Lighting Lariat. 2003 Ultra Classic
What are the outside temperatures you want precondition before departure?
Winter is coming in Southern VA and wondering if I really need to plan my a.m. departures if it is above freezing. I did watch a video that said the batteries are fine between 32 and 113 degrees.
I work from home and only go into the office occasionally, and that is usually anytime before noon. never consistent.
