FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62
ExCivilian
'22 Platinum
I think you're missing the [2.112.91] portion in your readout!
Yes, I'm missing it. That's my concern, does anyone know what that means?
Just to be clear, mine literally shows 0.0: I didn't write that in like an X.X: placeholder if that makes sense.
I haven't seen anything which documents what the codes mean.
ExCivilian
'22 Platinum
Am I on the latest version?
The triangle has been showing since the last time we were talking about this a few months ago :( I think it's been there since I've it (a whole year).
That would be the current version, it's what I have.
Odd that the triangle hasn't dropped off by now, when I last updated, it lingered for a period of time.
Try shutting down the EVSE at the circuit breaker for 5 minutes, then restart.
ExCivilian
'22 Platinum
I've tried powering it off at the breaker at least once a month since I've had it over the past year :) it's never changed anything in regards to the triangle.
I have the second one setup at a different house and it shows the correct version number (same number but with 2.112.91 instead of 0.0). The only problem there is whenever I look at them via Ford Pass one of the selection squares is blank and then I have to go through the FCSP app to reconnect it to Ford Pass and then I can see everything...then when I close everything and come back it's blank again.
Hard to explain but it looks like this:
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_A5675AB51AD8-1
I can't click on that white box, either. I have to go back through the FCSP app and reconnect it to Ford Pass each time. After the initial connection it is all prefilled and just takes a few seconds hahaha.
Weird, unfortunately I and most of use don't have multiple FCSP associated to our trucks, can't help debug what is going on with the above.
To clarify though , the orange triangle is what I'm referring to near the version number.
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1702432648673
ExCivilian
'22 Platinum
Yeah, I've always had that orange triangle no matter how many times I've flipped the breaker off, or how long I've had it off, or what version it's on. I'll call Ford up next month when I go back out to our desert home. I'm really curious about the 0.0 prefix given the one I just installed has the full correct string.
I just hooked up the second one today a few hours ago so that's not related to my issues (and that red triangle is just because I'm not at the location so it's lost connection) but if anyone has a second one and has some ideas I'm all ears.
There are 2 different red triangles being bantered about here. Yours indicates no connectivity. The one in Taxman’s post is for “Update pending.”
ExCivilian
'22 Platinum
Yes, I have both the orange triangle that indicates update pending on my old FCSP even though it's on the most current version. The red triangle is just alerting me that I've lost connection (because I'm at a different residence). I edited the photo so there is less confusion.
The reason I posted that picture was because of the white rectangle that has nothing in it, which is supposed to be the second charger I just hooked up today.
Two sepate issues:
1. My Fordpass shows 0.0:2.149:1.32:1.53:0.62 and FCSP app shows 0.0:2.149:1.32:0.62:1.53 with an orange triangle for my first FCSP.
2. My Fordpass has a blank entry for my second FCSP. If I go through the FCSP app and "connect" it to Ford Pass I can go into settings and see 2.112.91:2.149:1.32:1.53:0.62 so it seems like the orange triangle may be related to the 0.0: in the first FCSP.
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_AF7BE7D3FDE0-1
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_5214.PNG
I deleted both charge stations and started over and now I'm left with this:
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 IMG_04F73541CEB0-1
How fun! I'm going to have to call Ford in the morning.
This morning my FCSP was showing the normal standby mode (solid blue light bar) after finishing the morning charge and powered remote start. Unplugged the truck, heading out for breakfast & coffee.
I checked on the FP app as to the status of the FCSP via ACCOUNT / Charge Station, after loading, it showed the normal graphic of the FCSP but the animated blue lamp was pulsing just like it should while charging or energizing the truck when plugged in. It also showed "Charging" as the status condition, obviously it wasn't because I was 2 miles from the house.
Later it stopped responding at all via the Fordpass app, after clicking the tile the sub-app would not load the status condition of the FCSP.
When we got home, I checked the online network, it was visible, I could log into it and noticed that the software version appeared to by in a mid state of change, we've seen this in the past... partial data for the current version.
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1706124803024
This has happened in the past on my and other FCSP's, subsequently it repopulates with either a newer version or the same version as previously listed.
I've power cycled the FCSP, confirmed that it's still visible on my local network via the FCSP Setup app, but still the unit is not talking to the Ford cloud, I suspect back room operations are the issue, maybe an afternoon boot might be in order at headquarters @Ford Motor Company .
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1706125792798
Ffxdude
22 Lightning Lariat ER
Yep. Blank screen over here too. Maybe it's a new feature - sketch your own charge rate?
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 1000235102
sfringer
Scott
NC
I see the same. Just getting around to checking on things after the mobile tech left from handling the 23B70 CSP.
Labs4Lightning
C
Mine lost connection with app this afternoon when I checked,
‘was working/connected last night
glad you posted - I’d be out there wasting my time trying to get it to connect.
We're back online, pending update?
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 SmartSelect_20240125_132342_FordPass
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 SmartSelect_20240125_132248_FordPass
Ford F-150 Lightning FCSP Software Version 2.112.91:2.149:1.32:1.53:0.62 SmartSelect_20240125_132319_FordPass
Labs4Lightning
C
