Charge station pro cannot connect to charging station
rayray0114
Ray
2023 F-150 Lightning
Same here. Still showing Connection Lost.
MrH42
Cincinnati, OH
2023 Lariat ER, 2024 Miata
Glad I found this thread. Got my charge station installed yesterday. Finally got it hooked to my wifi. The setup app recognizes it, but couldn't get it connected to Ford Pass no matter what I did.
Looks like it isn't just me. I'm surprised it's been down this long and Ford support doesn't have a way of knowing if the server is down.
I suppose we should be thankful it at least still charges. I haven't tried to access it recently, but charging hasn't been affected. Still starts when it's supposed to, though I haven't gotten any details from it in ages. I need to save up and get the Emporia Vue system.
A solution to your problems that I’m glad I finally did. Sell the FCSP and buy an Emporia EVSE (or other). Besides a better app I enjoy not having to pull down the little flap and connecting that big honking CCS plug and its bulkier cable into the truck with its extra DC pins I’ll never use at home.
I'm [im]patiently waiting for @EmporiaEnergy to finally release their bidirectional unit. I'd happily eat the cost of the FCSP if I can't sell it as long as I can get Emporia's unit to work for backup.
2sleep
Bob
Western NC
23 Lightning Lariat Antimatter Blue, 2008 Prius
Pardon my ignorance but what app are you using to get this charging information. I downloaded the App that helps you set up the charge station pro but deleted it after set up per FCS. Is there another Ford app or a different app that would connect the ford charge station pro to the wifi and give me that information?
Stang68
NJ
Mach E GT Performance, Lightning Lariat Extended
Once you have the FCSP set up through the setup app, then you use Fordpass to view status and info.
Ford Pass / Account / Charge Station / Insights
Ford F-150 Lightning Charge station pro cannot connect to charging station 1707913911362
Ford F-150 Lightning Charge station pro cannot connect to charging station 1707913962908
@Ford Motor Company How much longer to get the operation & service restored????
I tried changing my charge limit at home to 70% last night. It said it saved, but I had 80% when I woke up this morning. I suppose I should be happy it didn't go to 100%, but come on...it shouldn't be this hard.
Do you still have an active session? Mine dipped out last Thursday........
Ford F-150 Lightning Charge station pro cannot connect to charging station 1707924240277
Nope, have the same connection lost. I thought maybe I'd still be able to change time or max SOC but nope. Will make the change in the truck.
