Oil Change on Lightning
vic7780
Victor
Quantico VA
F-150 Lighting - Atlas Blue, Max Tow, 511a Package
Citizen
When I pulled the snap shots, they were from my local static copy of the manuals downloaded months ago, so, I dialed up FORD.COM, logged in and pulled the current version of the manual based on my VIN, this section is basically the same for the 2022 MY.
Are the manuals on this site? I love learning more about my lightning.
No, but you can access the OWNERS MANUAL directly from Ford.com, there are HTML and PDF versions to peruse or download.
The SERVICE MANUAL can be subscribed to, I don't recall the thread but there is a service to getting a customized version for your model year.
247JAK
Joshua
23 Lightning
I have drained and filled my own drive unit fluid. I did it at about 10K miles. Even though the service interval doesn't call for service until 150K, whenever gears are breaking in, there will always be some degree of wear material imparted into the fluid, so just to be prudent, I checked the service manual for the spec (just a standard ULV transmission fluid) and used a fluid extraction pump to remove the old fluid (since after inspecting the fluid, I had no doubts that the filters and filter screens were probably barely contaminated. I then filled with fresh ULV fluid up to proper lefel (up to the fill port).
Super straightforward and now I feel 100% confident in running it all the way to 100K+.
If you guys are interested, I can post pictures and more if you'd like.
Also, as for brake fluid service, any decent bi-directional scanner can execute the bleed function.
If you still have pictures please post the filter location and fill plug
ctuan13
Chuck
Pittsburgh, PA
I don't have my shop manual PDF readily accessible right now for detailed diagrams, but I can leave you with some of the pictures I took while doing the service. I've also included a picture of the box of one of the screw on filters so you can see the part number. (both motors use the same filter)
The rear motor fill plug is on the driver's side and the front motor's fill plug is on the passenger side. The screw on filter for each motor is located on the opposite side of the fill plug. There is also an additional filter screen inside the gearbox housing, but there is no reason to remove that for service for a LONG time as unless there extremely large particles (ie potential gear damage), all the wear material should be caught in the screw on filters.
Ford F-150 Lightning Oil Change on Lightning 20231119_070437
Ford F-150 Lightning Oil Change on Lightning 20231116_163750
Ford F-150 Lightning Oil Change on Lightning 20231119_065445
Ford F-150 Lightning Oil Change on Lightning 20231119_080329
Ford F-150 Lightning Oil Change on Lightning 20231119_080403
Ford F-150 Lightning Oil Change on Lightning 20231119_073028
247JAK
Joshua
23 Lightning
Ur awesome thanks!!
I was thinking about putting the AMSOIL UL @ $22 a quart like 10 quarts
any thoughts?
42k miles on ‘23 and just now only back motor working and derated to 56% after a 40 min update
Ur awesome thanks!!
any thoughts?
I'm a fan of Amsoil but there are others out there too. High Performance Lubricants comes to mind.
Depending on climate, I would look at viscosity of the various options and maybe look to see if one is on the lower side to maybe eek out a bit of an efficiency improvement. With HPL being a blender I debated reaching out to them to see if they had thoughts on a custom blend focused on efficiency.
Ur awesome thanks!!
any thoughts?
You’re not going to fix the 56% issue by doing an oil change. It is a programming issue with that update and your truck will be fine after a drive or two and/or being off for a while.
247JAK
Joshua
23 Lightning
I just finished a 3 hr drive with no issues and was not derated
yes I agree oil will not fix the 56% one motor bug issue
just so happened to have had this bug come up first powertrain issue
ADHD
247JAK
Joshua
23 Lightning
https://www.hplubricants.com/category/automotive-lubricants/
I’ll look into HPL ironically they are only 30 minutes away from the house where the manufacture the products
I’ve never heard of them looks like a legit facility many sponsors
falcatum
Aaron
Lariat ER
Does anyone have the torque spec for the oil pan bolts?
You realize it doesn't need to be changed until 10 years or 150K miles.
But otherwise it's in the workshop manual, need to reseal the pan with RTV, then :
5. Install the transmission oil pan and the bolts.
Torque: 97 lb.in (11 Nm)
falcatum
Aaron
Lariat ER
Thank you! Yeah, I know. But I have 80k now in 2.5years. Im getting nervous about wear particles. I need to get a copy of the shop manual!
