What is your SOH, Mileage, and how do you use your Battery?
snb2557
Sam
Austin
2023 Lightning Lariat ER
Software Engineer
No towing and I don’t think I’ve ever hauled anything in the bed too heavy. I do live in Texas, so plenty of heat. I keep it in a garage when not driving / away from home. I also wondered if something hadn’t been reset ?‍♂. I was told Ford had to arrange for assistance when the dealer started doing the module swap.
Maxx
Maxx
Look at it this way; If the battery is good and BMS is confused, you may get your battery upgraded before your warranty is over because BMS thinks your SOH is under 70%.
You could do your own calculation next time you charge to 100%. Look at your actual SOC and energy in Car Scanner and go down to 20% and do the math to see if your actual battery capacity has dropped by something close to 93.5%. This is not fool proof since some of the data you are using may be the same false data that confuses BMS but at the minimum is additional info for you.
I had 1% drop soon after some of our hottest days here followed by a short fast charging but it may be a coincident. You can compare notes with other owners in Austin.
Kansan
Wayne
2024 Flash
Civil Engineer
8400 miles. 100% SOH. Fully charged it shows 131.07 kWh. I charge to 80% nightly and 100% before a trip - probably only 5 or 6 Times so far. I’ve probably DCFC 12-15 times - half of those on Tesla superchargers with peak rates as high as 190 kW. I’m not easy on it and have seen over 450 kW draw from the battery during takeoff many times.
I noticed my variation in battery module capacity has gone down after charging to 100% - it was over 16 Ah when I bought it, went to 9.8 the 2nd time I fast charged and now it’s 4.2 Ah.
I thought I had a good printout of the FDRS battery report, but it got truncated
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? IMG_9525
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? IMG_9526
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? IMG_9725
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? IMG_9726
SpaceEVDriver
Arizona
SoH: 99.5%
15455.2 miles
Battery age: 18.37 months
wpy8912
2023 F150 Lightning ER
SoH: 100%
11000 miles
Battery age: 22 months
SmoothJ
New Jersey
2022 F150 Lightning
SoH: 100%
30419 miles
Battery age: 35 months (6/18/2022), 1 module replacement (5/2024)
Max average charge: 90% (based on GOM)
DCFC: ~3 times
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? IMG_1920
wpy8912
SoH: 77%
38019 miles
Battery age: 36 months (5/15/2022)
Max average charge: 85% daily
DCFC: once a moth or so, before long trips
If that soh is true, you should try to let your battery stay at 100% or 0% longer, so that you will have the soh droped below 70% sooner, and let Ford replace a new battery pack for you.
Texas Dan
Daniel
The reason why SOH is 100% is the module replacement. It takes 22 days for the BMS to be accurate after that work, per Ford.
Display SOC is what shows in the vehicle.
SOC is what the actual battery has., including what you can't use.
It has been over two months since the module replacement and my SOH is still showing 100%.
ctuan13
Chuck
Pittsburgh, PA
SOH: 100%
Odometer 25,100.5
Battery Age: 34.37 months
Battery module voltage variation: 0.01V
Battery module SOC variation: 0.28%
Daily charge limit: 90%
Charging practice: never let it drop below 40% except on road trips and will only plug back in if returning home below 80%
DC Fast Charging (total sessions): 90
50kW sessions: 29
120kW sessions: 12
162kW sessions: 49
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Software Development
Getting nervous with my 2022 Lariat LR battery SOH since it started jumping all over the place.
(dates are estimates from when I first noticed it)
04/01/25 - SOH 100%
04/15/25 - SOH 99.5%
05/01/25 - SOH 97.5%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
4% loss in 10 weeks seems a little extreme given that I've been at 100% for a loooong time until recently and treat it so well. Only DCFC 3 times and keep the charge anywhere from 40% to 70% on the Ford slow portable charger. Truck just hit 30k miles.
Any way I can diagnose the battery modules myself with Forscan or some other tool?
Thx!
wpy8912
04/01/25 - SOH 100%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
Thx!
That's normal. The reason it shows 100% for such long time is because of it's eating the buffer, which is around 8% of total capacity. After that, it will start to eat the usable capacity....
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Hmm. Not sure that sounds right. That would mean my battery has lost nearly 11% of it's total capacity which would definitely not seem normal. When I look up data in Carscanner, it clearly shows a difference between SOC and displayed SOC, so the buffer still exists.
electricpig
Tim
Northwest Arkansas
04/01/25 - SOH 100%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
Thx!
Could be BMS drifting is an issue. Basically without going down to near zero, or 100% the BMS can lose track of actual. The SOH you are seeing is what the BMS thinks, and that may not be entirely accurate. Many people charge to 100% occasionally for this reason. I have read that the remedy is to run it to near zero, then in one continuous charge to 100% (meaning it shuts off on its own). This also has the effect of leveling all cells, meaning evenly charged which can throw off SOH calculations as well. Lastly, it's not just battery usage, it's also age of the battery pack, and environment, especially very high temps. But of course you may have a weak cell or two.
Try deep discharge to absolute full charge. Just keep it either end for as little time as possible.
Maxx
Maxx
04/01/25 - SOH 100%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
Thx!
That does seem like a fast drop. Have you had any software updates to BMS in April? I am thinking if it stayed at 100% for that long, may be it has been lying to you all this time and now it is trying to tell the truth a little at a time.
