The smaller pack in the ER battery is the same as the regular packs in the the SR, and in the case of a failure, out of warranty - better to have any pack then none at all...
They are the same size kWh wise (40 cells), but not the same configuration or part. All SR modules are 4P10S - 333V nominal. The ER small module is 5P8s - 355V nominal.
There would be a voltage mismatch - so not compatible.
kdkool
Atlanta, GA
2023 XLT Lightning / 2023 6.7L Lariat F-350
Yes to expand on this, the ER large modules are 5P11S. Essentially the ER and SR modules do not share the same internal battery modules, but the ER and flash do.
The SR is 98 kWh with (9) 4P10S modules. 333V nominal as a battery pack. 360 cells total.
The ER is 131 kWh with (8) 5P11S and (1) 5P8S. 355.2V nominal as a battery pack. 480 cells total.
The Flash is 123 kWh with (6) 5P11S and (3) 5P8S. 333V nominal as a battery pack. 450 cells total.
The modules themselves are just placed in series with one another so it isn't really a voltage mismatch issue but more of a BMS mismatch issue. The BMS would for sure flip out with the incorrect module in place.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
yes, all the packs need the same number of cells in parallel groups - for balancing reasons, so it makes sense. The ER small pack needs sets of 5 to match the other modules in the battery. Quite Right.
So the OP swaped out the SR to ER battery - but the BMS is exterior to the battery isn't it?
So the BMS 'sees' the larger number of cell groups via the connector and doesn't flip out?
OP said the truck recognized the larger battery immediately - this may be how it does.
kdkool
Atlanta, GA
BMS is internal to the battery pack. That's essentially why its plug and play because the truck just gathers and reports the battery status from the pack's internal BMS. The BMS communicates via a serial communication bus so it consolidates all the thermal sensing, contactors, voltage sense, and current balancing wires.
All the battery packs have 9 modules that are in series with one another. For the ER, there are (8) modules of (5P11S) and (1) module of 5P8S. The last single module being a lower overall voltage than the other 8. Cell balancing is done by the BMS for each of the (9) modules down to the cluster of 5 parallel cells. These battery cells are typically very well matched (very close in ESR) so minimal balancing should be required.
Each cell is roughly 81A.
5P11S => 55 total cells. This means there are 11 sets of 5 cells that are in parallel. The 11 set of 5 paralleled cells are then placed in series. Each cell is ~3.7V. Paralleled cells combine for more current. Cells in series increase voltage. So for the 5P11S module, the overall voltage of this module is 40.7V or about 16.5kW overall.
The small module is 5P8S which means it has an overall voltage of 29.6V and about 12kW overall.
This gives us the ER total voltage of 40.7V x (8 modules) + 29.6V x (1 module) = 355.2V.
Each cell is 3.7V x 81A = 300W. Since there are 480 cells in the ER, this gives us 300W x 480 = 144kW. Ford derates the battery capacity by roughly 9% to avoid the extreme conditions of fully charged and completely drained for maximum battery life. After the additional derating, this gives us the advertised 131kWh rating.
SMMD
SF Bay Area
You are unbelievably amazing! I assume you probably lack some of the fear/survival based circuitry that most of us carry around in our heads, which I guess sometimes can be a good thing.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Thanks so much for your last post. I have screen shots taken from Monro excellent video from 2 years ago, link:
I didn't understand at the time much about the battery and your post has helped me. I believe this screen shot below is the small module from their ER battery using the 5P8S configuration. These notes on the screen shot are 2 years old (wrong?). I have been confused all this time about the apparent 9 "cells" per "brick" and apparently 2 pouches per cell?? Does this match with your excellent post above?
Ford F-150 Lightning SR to ER battery swap DIY project 1763563437641-2g
flux capacitor
2023 F-150 Lightning
What ever the case after the 8 year warranty we are all on our own and if you can pick up whole batteries on Ebay from wrecked Lightnings at this price they should really be cheap in 8 years and maybe all new replacements like solid state batteries or something new. This project shows that we are just as before with ICE's swapping engines in cars it is just have to learn the new lingo.
Thank you kdcool for being brave enough to try this. It sure has opened up a lot of possibilities for the future and answered questions we all were wondering about.
SpaceEVDriver
Arizona
Question: How were you able to confirm that all the modules and cells in the new battery were in good condition? Or did you bother? Or did I miss that in this thread?
rdr854
Northern Virginia
So there is a 8yr warranty on the battery what happens when one or two battery modules have a mismatch voltage issue how are you going to take care of that? Will Ford honor the warranty with the Vin says it is a SR? Or you are now on your own? Back to searching eBay for another ER battery.
The first month I got my 23 ER I had that problem of one battery module and it took 2mos to get that one module replaced.
My guess is that the warranty would not apply for two reasons: (a) the truck that the battery came out of likely had a salvage title which would automatically void any OEM warranties for any failure related to that part and (b) the battery does not match the build sheet specification. Thus, I would expect an OEM such as Ford to treat the new battery as an aftermarket part rather than as an OEM part.
This is no different than going to a salvage yard and picking a part from a junked car.
kdkool
Atlanta, GA
Its a gamble. Luckily it worked out for me.
SpaceEVDriver
Arizona
GoodSam
Good
occupying space
Grencola
G
Kelowna BC Canada
f150 lightning xlt 312A standard range
Tile Setter
Thanks so much for doing this, gives us all a bit of hope for future upgrades! 👍 Next step is to show us all how simple it is to add that second cooling loop to enable max towing 😂🤣😎
