25C69 Recall - Ford Recalls 2022-2026 F-150 Lightning Over Rollaway Risk
Direct links to recall documents:
https://static.nhtsa.gov/odi/rcl/2025/RCLRPT-25V863-7819.pdf
https://static.nhtsa.gov/odi/rcl/2025/RCAK-25V863-3736.pdf
NHTSA Recall No.: 25V863
Manufacturer Recall No.: 25C69
Vehicle Rollaway Risk/FMVSS 114
A loss of park function can allow the vehicle to rollaway, increasing the risk of a crash.
NHTSA ID Number:
25V863000
Manufacturer Ford Motor Company
Components POWER TRAIN
Potential Number of Units Affected: 272,645
Summary
Ford Motor Company (Ford) is recalling certain 2022-2026 F-150 Lightning BEV, 2024-2026 Mustang Mach-E, and 2025-2026 Maverick vehicles. The integrated park module may fail to lock into the park position when the driver shifts into park. As such, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 114, "Theft Protection and Rollaway Prevention."
Remedy
The park module software will be updated over-the-air (OTA) or by a dealer, free of charge. Interim letters, notifying owners of the safety risk, are expected to be mailed February 2, 2026. Additional letters will be sent once the final remedy is available, anticipated in February 2026. Owners may contact Ford customer service at 1-866-436-7332. Ford's number for this recall is 25C69. Vehicle Identification Numbers (VINs) involved in this recall will be searchable on NHTSA.gov beginning January 26, 2026.
Joe.....Montana
Joe
Montana
2023 Lightning
I seem to remember at least one forum member talking about their truck rolling away after putting it into park. I also remember several other members telling them (it much more words) they were crazy and they must have done something out of the ordinary. Wonder if they experienced this issue.
chriserx
Louisiana
I always thought the park system was a lil wonky, like parking on an incline causes the vehicle to roll backwards a couple inches. It acts like somewhere in the drivetrain/motor there is a disc with holes and an actuator activates to 'lock' the drive wheels. Anyone know how the system actually operates?
You are pretty close. A parking pawl interacts with a gear to lock the transmission. On anything but perfectly flat ground the truck will settle a few inches forward or backward depending on grade.
I deal with this by holding the brakes while shifting to Park and slowly releasing them so it settles smoothly, without bouncing. If you don't want to truck to settle you can set the electronic parking brake.
Photo from Wikipedia
Ford F-150 Lightning 25C69 Recall - Ford Recalls 2022-2026 F-150 Lightning Over Rollaway Risk 1000020744
K6CCC
Glendora, Calif.
Sounds like a really good reason to get into the habit (if you don't already) to always use the parking brake.
Jamchampnate
Nate
Utah
Ford lightning 23’ Lariat
I’ll take a Powertrain update please! PPO with the truck off here I come!
Will this sort of update require a power train update? Now this would be nice.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
Yes after a forscan change. I made the change in forscan, but it won’t work till I get the powertrain update
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Back when this first came out most of us watched it. There are a lot of new people here so it’s probably worth a repost. Munro did a complete teardown and posted some interesting videos.
Edit: the link was supposed to take you to a playlist but it seems to link to the battery video. There is a series and you should be able to find the rest.
Yes, this case was related to parking on an incline in the winter. Twas ice related. But it's possible there was another case that I didn't see.
However, someone did have a broken pawl that caused an internal failure of the gearbox.
chriserx
Louisiana
Lol I was wondering, I've actually seen it but it had been a while so I went ahead and rewatched it anyway.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
It is interesting that there is a description of mechanical issues and friction as the source of the problem, however, it can be corrected with a OTA update?
Rice_classic
Rice
2023 F150 lightning lariat ER
I have been setting a parking brake for 30 years. Not stopping now. I pull that little lever every time I park so I don’t have to worry about a pawl. I also park on a downward slope toward my garage so I don’t want any risk.
Scorpio3d
SS/IBA car wash owner
I park on an upward slope toward my garage, so I have always used my parking brake (even when it doesn’t do it on its own) because it is habit even when not parking at home.
