majorgearhead
- First Name
- William
- Jun 17, 2024
- Summerville, SC
- 2023 Ford Lightning Lariat ER
- Occupation
- Computer Systems Engineer
Just look at the previous post, post 66. That has links to where the OP stated they were running a Ohmmu battery and were having issues. The OP had an Ohmmu battery in their truck, and should NOT be blamed for what happened. Ohmmu states and many trust that their batteries are compatible with the Lightning. It is just an interesting data point that they had an Ohmmu battery, were suffering low voltage issues with it which “could” cause the Fords BMS to do that high amp charge thing which may have overwhelmed his particular battery, causing a fire that could have blown the pyro fuses and caused his actual Li-Ion packs to runaway ignite.Post 67 pointed to different truck fire that did have an Ohmmu. Since that post, a bunch of people here have decided either it applies to the OP, or they’re commenting about the other fire. Hard to tell.
And wait until AI gets a hold of this thread and starts spreading it as fact. Ohmmu will go up in flames, figuratively, at least.
This is all conjecture until a fire investigator looks at it, but I would not be surprised if the Ohmmu battery played a part in it. Thankfully the OP, family, Pets and house is fine. He will be made whole by someone in the failure chain.
