2024 Platinum replaced 2023 Lariat 1st impression
flyct
Jerry
South Florida
Blissfully Retired
I replaced my 2023 Lightning Lariat ER with a new 2024 Platinum last 10 days ago.
Here is my report after only 10 days of ownership and 335 miles on the odometer.
Range:
  • Definitely about a 5%-10% reduction in range at 60-65 mph trip 2.0 vs 2.1 MKH at 60-65 mph on the GOM.
  • The 125 trip I routinely do took 65 kWhs where the Lariat ER took 59-61 KWHs to replenish.
  • I feel road abnormalities more in the Platinum. Feels like tires ride slightly stiffer.
  • Ride is much less "floaty". Truck feels more "Planted". I don't know if its the spring rates or calibration of the shocks.
  • PaaK walk away lock works flawlessly when using my iPhone
  • Massaging seats make in "Relaxed" mode sooths the back and my butt on rides.
  • Ability to use ProPower onboard with the truck turned OFF works great to precool our powered coolers before a trip
  • Throttle response is more ICE like.
  • The Platinum has a Gloss front "grill" which looks like it will scratch easily compared the Lariat when removing Florida Bugs
  • Upgraded Blue Cruise seems to only give me the addition of automatic lane change when signal light is activated on mapped roads. It does nothing new on unmapped roads
  • Ford offered a killer deal on leasing. 0.05% interest on the lease and $21,615 off MSRP and a 55% residual with 39mo/7,500 mile lease.
  • Surprised it has "propulsion sounds" when getting on it.
flyct
flyct
Jerry
South Florida
Blissfully Retired
Oafy44
Georgia
23 ford lightning
Landscape contractor
No, It's more toned down then my 2023 Lariat.
Since I did the same thing - yesterday I put it in sport mode and it actually seems smoother to me / much more like the 23 lariat in regards to take off…..for obvious reasons but the steering /suspension almost felt a little softer which I don’t get .
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
It definitely does scratch extremely easily. Mine will need to be repainted soon.
That can be turned off. I don't know why anyone would want that on. It's a stupid feature.
You should also notice quite a difference in the sound system, at least if you're playing from a high quality source.
Zaptor
.......... Trophy husband
I live in the woods. It's gorgeous here, but I often encounter deer, bobcats, cougar and sometimes neighbors and their pets along the twisty road home. I see them a lot more with my Lariat (no propulsion sounds) than I ever did with Hemis and Cummins and other naturally loud rigs. I didn't want most of what the platinum offered beyond my trim level, but I do wish I could turn that on to give some advance warning of my impending arrival in their space... I guess I'm the use case, lol
Cheers
Zap
mattskr
Matt
Austin, Texas
Cheers
Zap
your situation makes sense, but this feature is only audible to passengers inside the truck.
Zaptor
Hah! If true, then I don't covet that feature either. I'd rather listen to my music. Thanks for the clarification and yeah, that's dumb.
Cheers
Zap
Congrat's, the tires on a Platinum are 22's giving a firmer ride.
Hammick
Somewhere in MT
Congrats on the upgrade. Please tell us more about how PPOB works with the truck off. Can you control on/off from FordPass?
flyct
flyct
Jerry
South Florida
Blissfully Retired
When ProPower is selected there is a switch on the 15" screen to select it on of off with truck turned off. Then just turn the truck OFF and power remains at each outlet until battery threshold to shut it down is reached. The selection does not remain for future starts. It must be reselected after each startup of the truck if desired.
I have not found anything on Ford Pass to monitor or control it ProPower Onboard. In past FP versions there was ability to monitor the power consumption on each output. I really miss that feature. I n the past I could power the cabin and go to the well pump, turn the well pump ON and monitor the current the pump was drawing with the APP. I really miss that feature.
flypony53
Rodney
Houston, TX
Ford F150 Lightning, Tesla Model Y, Tesla Model S
not sure how you Lariat worked, but my 22 Platinum rips, maybe I need to try a Lariat. I believe overall, the Platinum is slightly slower than the Lariat due to the added weight.
Wonder if they are tuning the 24's differently with the energy pedal.
Congrats on the truck. Agree with others, propulsion sounds are dumb. Every time I get an update (well, back when I still received updates), it was always reenabled by default. It might be different if it piped in some true sound like straight pipes in Sport mode or if I could upload my own sounds.
Rip
Rip
2024 Lightning Platinum
Quality Consultant
Have you tried it in Sport Mode? I found that made a difference. It responds more like the Model Y Performance that I traded in. I definitely take the ICE F-150s off the line. I've had a couple try to keep up...not a chance.
Oafy44
Georgia
23 ford lightning
agree but at least with my 24 platinum - the sports mode is almost smoother (definitely quicker off the line ) and should be the normal mode and the sports mode should be the normal mode if that makes sense…..at least compared to my 23 lariat.
the 24 platinum steering is stiffer as well in normal mode then my 23 lariat. I know this has been documented but since the 24’s charge at a slower rate then the 23’s - is that a software issue that can be OTA or is a physical reasoning to it ?
it’s a shame my 23 lariat gained about 35 miles per hour when charging at my 80 amp vs my 24 that barely gets to 20 . I knew that going in but didn’t think it would be that bad or noticeable.
If they can speed up charging at a super charger not sure why they can’t go back to normal charge rates then my 23.
