BennyTheBeaver
BennyTheBeaver
2023 Lightning XLT ER
Just received the 4.2.1 update minutes ago.
Now the question is, should I go to the dealer and still get the TSB 23-2050?
I'm not a qualified Ford engineer/technician but my understanding is you now have the connectivity fix, which would render the visit pointless.
Lucky for me I had another issue when I had the TSB done, so it wasn't a complete waste of my time. I can say that after the TSB was applied I again lost connectivity.
Hatchback
Pete
Silverado 1500
I received 4.2.1 fix today. Mine has been disconnected since 3/4. I never reset it as I was tired of doing so. I still was able to get the update. I do have it set to connect to wifi at home and I am guessing that's how it came through. Everything is working now. Hopefully it stays that way.
bellyer
Chicago
2021 Mach-E FE & 2023 F-150 Lightning Lariat ER
I received 4.2.1 on March 3rd after having disconnected my battery and I can say that I have not experienced a modem disconnect since. It had been happening 1-2 times per week since getting my truck back in late November. Crossing my fingers it is fixed for good.
BennyTheBeaver
BennyTheBeaver
Someone on Facebook mentioned that they recieved 4.2.1 twice. I don't know how credible it is, but keep your eye open in case you get a 2nd update.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I've had my Lariat ER since 24 January & 3,800 miles & don't think I've seen any updates to date, tho I got a notice from Ford of one coming. Screen says I'm up to date. Everything works fine, FordPass talks to the truck & I can do all the functions on the IOS app without issue. Beuing a veteran "if it ain't broke don't fix it" guy, I hesitate to rock the electrons.
bellyer
Chicago
My Mach-E got 4.2.1 and 4.2.2, which both seemed to have the same release notes. Not sure if that is the same sort of situation you saw on Facebook.
BennyTheBeaver
BennyTheBeaver
Interesting. The one I'm referencing is someone that got 4.2.1 earlier, then got it again today. Who knows the validity of that though?
3rdgenfan
Geoff
Delaware
Randomly had a message that an update was performed, looks like it installed 4.2.1 and also fixed the app communication at the same time. Guess we'll see how long it lasts.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
The TSB has been cancelled so your dealer won’t be able to do it. The update replaced the TSB.
KrazyEd
Ed
Las Vegas, Nevada
2021 MME RWD SB, 2018 Zero FXS, 2014 Zero S
Taxi Driver
I picked my 2023 XLT up in January. No issues. After getting used to it for a few weeks, I started
playing around with it a bit. One of the things I played with was using the truck to power things
around my house. It appeared that a day or two after this, I would have an issue of FordPass not
communicating. No drive or charge reports, no lock unlock, etc. I would disconnect the 12 volt
battery for a few minutes and things would work again. It has been working for the last few days
then this morning, I got the update. Hopefully Ford has hired some of the programmers who have
been let go from other Tech companies.
Arrington.LCA
Luke
Colorado
Just got 4.2.1 about 10 minutes after doing battery reset to get truck to talk to FP app again. Had been about 5 days since I last lost connection. Was shocked to see 4.2.1 since I it had been since 2/14 that I’d gotten my only update prior in the truck to 4.1.2. Usually modem goes a few days connected and then stops again, so we’ll see if this causes it behave any differently.
Maxx
that their Engineers are aware of the glich and that it may of been caused by 4.2.1 updates and they presently working on it.
I was afraid of leaving it on auto update. It is like giving my truck keys to a bunch of drunk blind monkeys but now that they are driving it, it may be too late to ask to have the keys back. I am now a part of that perpetual fixing and breaking cycle. I absolutely expect problems with a new design; Rivian has it, GM has it and Tesla has it too but rolling out a truck without OTA process hammered out and without communicating the initial software version number is a bit unprofessional. The fact that this update description says the same thing as the last one may means monkeys writing the code may be doing drugs too. If this indeed includes a modem fix and they didn’t want to put all fixes in writing, we are talking dishonest monkeys too.
p.s. got 4.1.1 in January and now 4.2.1. Still love the truck and still afraid of auto update.
Got the update and the next morning fordpass would not start or unlock my 23 pro
Sometimes the problem is not the truck but the actual app on your phone, happens with mine so I force stop the application, and sometimes I need to clear the cache.
roddiaz1
Rod
Pittsburgh
Maxx,
I'm right there with you.
I'd like to know more about what all is in these updates before installing them.
