LUXMAN
F150 Lightning PRO and XLT
Pilot
Added a Gator EFX today
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 10FB043D-3250-44D9-991A-11DC817D1B26
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 03C27E39-7E24-46CD-9BD8-692C71755D57
boggle
CT
MY23 PRO
Dampening tailgate hinge successfully installed. Removing the tail light was one of the scariest things I've done in a while. Here's a clearer look at the stud if anyone was trying to visualize the mount point on the truck. Unhinged just the right side of the tailgate and rested it on a sawhorse and was able to get the hinge swapped easily. Shout out to all the red threadlock and paint that made these bolts so difficult to remove. Recommend spraying some brake cleaner up the bottom of the threads to help loosen it up.
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 1675008015440
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? 1675008209583
Broonarmy
F150 Lightning, 2022 Lariat ER, Smoked Quartz
My first three mods done.
- RetraxPro XR which I am very impressed with. (big thanks to @Realtruck for the service and the discounts!!)
- Stubby Antenna
- Mounted front license plate using the Mishimoto tow hook kit.
Accessories are going to bleed me dry, I suspect I have opened the floodgates o_O
Lightning Rod
The North Coast
2023 Ford Lightning Lariat ER
PROGRAMMER
- Stubby Antenna
Does that stubby antenna receive signal just as well as the oem antenna? Also, which stubby did you go with?
Thanks.
BennyTheBeaver
- Stubby Antenna
It becomes an addiction.
I've never wanted as many accessories as I do on this truck (partially because I got the Pro, and partially because I may actually be in love with my truck).
Broonarmy
Thanks.
Not sure yet on the reception. I will test over the next couple of days and report. I rarely listen to radio if I'm honest, mostly Spotify.
I went for this one which a few others had recommended.
Broonarmy
- Stubby Antenna
Number 4 today.
I put in a Husky frunk mat. First impressions not awesome if I'm honest. It's ok and it fits sort of well but it's definitely more slippery plastic material than the rubber I was hoping for. Also it came rolled up so it's going to take some flattening out.
Not sure if there are any alternatives so it will do for now. It will still protect for sure.
GoodSam
Good
occupying space
While checking to see if a 10"x10" hard plastic sheet piece run over on the freeway had caused any damage (made quite the noise), I noticed that this underside long plastic moulding (both sides behind running boards) was tapping annoyingly on the steel frame when lightly shaken. Added self-stick 2" long rubber 1/4" weatherseal at the spot where it was hitting which seems to work. What is function of this long plastic molding? Aerodynamics?
Ford F-150 Lightning πŸ™‹β€β™‚οΈ What Did You Do To Your Lightning Today? IMG_20230130_162711278 self-stick rubber weatherseal to stop underside plastic guard from mak
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
This is gorgeous! Wrapped I assume? Taillight tint? Details please!
Indeed! Stealth PPF wrap. Smoked tails. Painted light bar. In the shop getting level-lift, new tires, powder coating the rims, electric running boards… pics to come when I get her back.
Lytning
Georgia
- Stubby Antenna
You just have GAS ... Gear Acquisition Syndrome.
Lytning
Georgia
