What is your SOH, Mileage, and how do you use your Battery?
Texas Dan
Daniel
I connected a bluetooth OBD II transmitter to my Lightning for the first time so my ABRP app could read data from my Lightning. ABRP indicated I have 3.5% degradation on my battery pack. I have over 24k miles on my Lightning.
I think this amount of degradation is as expected. I did expect the buffer to soak up the degradation for a bit longer. I’m not sure how much I trust the readings from the ABRP app but I will keep an eye on these numbers to see if the degradation levels out or continues to get worse.
BTW, charging has been about 50% L2 and 50% DCFC, lots of trips between Texas and Colorado.
mq019
2023 F150 Lightning Lariat ER
2023 ER Lariat, just over 16K miles, HVB age 9.5 months, SOH 99.5%
Maybe used a DCFC 15-20 times max - probably less.
Lowest its ever been is 9% (that was a "fun" trip) - usually don't go below 20%
I get free charging at work, so I charge there as much as possible. Usually no more than 90% unless I know I'm doing some distance driving in the next day or so. Usually try and get it down to around 30% before I start charging again. It probably averages 50-60% if I had to guess. When its hot (over 80F) or cold (below 50F), I keep it plugged in but not charging at home so that it can (hopefully) thermally manage the battery.
But mostly, I drive it in 2 pedal, sport mode, and while I don't regularly launch it, I do drive it "in a spirited manner" :wink:, use the heat/AC as much as needed to keep me comfortable, and overall try not to worry too much about it.
mr.Magoo
2022 Lariat ER, AMB
Mine is still at 100%, 20 months old, DCFC maybe 30 times total.
[Edit] forgot to mention I have roughly 14,500miles on it.
Michigan weather, so we do get colder temperatures, but I don't precondition and I never follow ABC (not deliberately, I just can't).
I charge when I have to (generally between 20-30%) and I charge to 80%.
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? 20240629_102256
Maxx
Maxx
Maxx
Maxx
8 year old Model S. Apparently with original battery and motors and 430,000 miles. Battery SOH at 72%. I would love to know what SOH would have been on this car if it put the same mileage on it in 20 years. We already have some high milage (100K) Lightnings out there. I am looking forward to see similar results for our Trucks.
Anyone knows what the Battery failure rates has been on these sedans? Is this a unicorn or is it normal?
GoodSam
Good
occupying space
I noticed 100% SOH at 8K on my 2022 XLT SR
Also, 13K showed 99.5% SOH.
UPDATE 3-1-25: 99.0% SOH at 15K, age 28 months, mostly home charge to 80% at 40A, except several times when Ford Nav cannot find my house and it goes to 100%, which actually may have been good for cell balancing? A few DCFC only for longer trips, probably only a dozen times. Cells now at 3.92Vdc with 0.33% variation (why does Car Scanner say "module" instead of "cell"?)
Maxx
Maxx
My understanding is that a bunch of cells (I forgot how many) in each module are connected in parallel and a bunch in series so if one cell in the parallel group has a short, the whole group voltage drops and the total voltage for the series drop as well. So since one bad cell means replacing the whole module and measuring the module variation shows if there is a bad cell, it makes sense. At least that is my understanding. Since the techs can see individual cell voltages, the info is definitely available somewhere, apparently not in car scanner.
Not sure if in packing the cells in the modules, if they are put in series first or parallel first.
Edit: Correction: Based on what @TaxmanHog noted bellow, what the tech sees must be the voltage for each of the parallel group of cells in the module not the individual cell.
Battery pack has 9 modules in series, each module has multiples of pouch cells in parallel that are in turn wired in series, SR trucks has one fewer individual pouch cell in parallel.
At least that's how I understand the set up.
GoodSam
Good
occupying space
There are images of the 96 cells and their individual voltages shown by the dealer testing software (FDRS?).
https://www.f150lightningforum.com/forum/attachments/1725282943760-fu-png.88550/
I think that there are 4 or 5 pouches, in parallel, SR or ER, per cell. Then the cells are in series, so 96 x ~4Vdc = ~384Vdc, somewhere in the nominal 400V battery range. The eight (#1-8) larger modules have 11 cells and smaller #9 module to the front has 8 cells.
But the 33% difference in capacity between the SR and ER is not explained by the 25% difference in "number of pouches/cell" 4p/5p, if that is correct.
Update from a comment by @Ford Senior Master : turns out that the ER is 5Parallel/96Series, the SR is 4P/90S, and the new Mid-Range is 5P/90S. Fewer cell groups in series is lower Voltage & less Hp. Fewer cells overall and fewer in parallel is less range. Modules: ER (8x11,1x8), SR (9x10), Mid (6x11)+(3x10).
See some of my original guesses and @Ford Senior Master info from a Ford Workshop manual are here:
https://www.f150lightningforum.com/...a-conversation-with-chatgpt.21142/post-416967
3 sr & 4 er ratio would account for the energy variation of 25% but I haven't seen it mentioned as a fact anywhere, could that be the reality instead of the urban myth based on another pack design?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
From Munro's battery tear down this is what I assumed the small front battery looked like for their ER pack. I assume the 5P-8S runs thru the large packs also for the ER battery? I have not seen confirmation of the 5P-8S pattern for the SR battery, but have assumed it to be the same.
Ford F-150 Lightning What is your SOH, Mileage, and how do you use your Battery? 1195KW~1
For kicks I got around to checking my SOH this morning. It said 96.5%. After doing my 100% to 14% to 100% test last week, the energy in my truck at 100% (and optimal temp) was 98% of listed capacity (I never checked what 100% was when I first bought it). Battery is 34 months old, I purchased with 600 miles on it Feb '23. Coming up on 39k miles now with 80% around town, 20% road trips.
I'm happy with that. Not sure why the SOH says 96.5, maybe from extended exposure to extreme heat?
Yes, these snapshots and the discussion in the video are what I recall. I would love to see the collector plate markings for all four variations they manufacture.
Recalling my technical school electrical theory, direct current cells in series add voltages, cells in parallel increase current capacity, the optimum current throughput will have uniform parallel groups across the entire series string, within and among the many modules.
Arriving with {ER 143 gross & 131 net} and {SR 107 gross / 98 net} kWh capacities
The shop diagnostic display show 96 cell groups, is this true for both SR and ER packs?
If so, the variation has to be 3 or 4 cells in parallel.
Grumpy2
23 F150 Pro SR
The confusion to me, what takes up the rest of the volume within the SR modules?
Maxx
Maxx
I hear heat is the enemy. I had a sudden drop after a hot day when the truck was under the sun followed by a short fast charging session (dropped to 98.5% when I was under 10K). It went down to 98% later and came backup to 98.5% where I am now at 16K and 26 months. I didn’t plug in the truck in last two winters. Not sure how much damage cold does.
People say it drops faster at first and then slows down but even if you go down linearly, you will be at 91% SOH at 100K. Not too bad.
