Charging error (All 5 segments turn RED) HVB Module failure
Please please try to eliminate so many abbreviations. Like many others, really enjoy the site but often confused by abbreviations
Y R U confd?
I've copied a resource created on the Mach-E forum to our forum located on this thread:
Acronyms, TLAs, and Initialisms
Won't work. That requires too much effort.
That list looks like it came from the US government. Who in the world can remember all that.
Open a browser window, and type into it that term you don't understand.
You're a retired surgeon & jet pilot, you have the mental acuity, stop being lazy and use your talents
Traconesu
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
This has occurred to a number of us. Reduced power is due to the failed modules.
I certainly didn't expect High Voltage battery failures with just a little over 23k miles. No DC charging. Local driving mostly 55 mph.
The Weatherman
Dean
South Central KY
There are definitely a larger number of Lightnings with failing battery modules than any of us here would have liked to see. It makes all of us a little more uncomfortable than we’d like for sure.
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
That’s what retirement is all about - getting lazy. I’m 87 years old and worked pretty darn hard all my life. Give me a break ?
2022 lightning platinum
Miles driven is irrelevant. You have a 2022, like many of us. Many threads here about the battery packets failing. It was just a matter of time IMO. DC charging has nothing to do with it, that's the HVBJB on the Mach-E...
Whammy Bar
I think you're right in that sweet spot for them to start happening. 5-25k miles it feels like
Ford F-150 Lightning Charging error (All 5 segments turn RED) HVB Module failure 1746909021542-ow
Piquette
Trent
New Hampshire
2022 Lightning Lariat
Losing three (3) battery modules (and all at once) certainly trumps the two I have lost over 20k miles and 20 months. It’s a common and well documented issue. What we don’t know is how likely are the remaining original battery modules to fail before the end of the 8 year/100,000 mile battery warranty expires. Regardless, it must be costing Ford a fortune in warranty costs.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Also, we don't know yet about the possible 1200+ Lightnings covered by the NHTSA and Canada Safety Recalls for fire risk that isn't limited by age or mileage. These are the trucks currently suggested to charge only to 80%.
Costs for a recall like this would fall to the battery supplier.
Traconesu
Traconesu
Patrick
I'm concerned about the damage these bad modules have caused to the other 6 modules too. As a retired electrician and a solar equipment installer I understand all battery cells connected in series or parallel are effected by each other. My truck is currently still in the shop. I decided to splurge and purchased a Launch X431 CRP919 EV car Scanner. It's designed specifically for EV'S and reviews say it has excellent diagnostics on HV battery modules. I will be keeping a close watch on the SOH of my battery from now on and request module replacements before they damage other modules as I'm sure what happened with me.
Vancouver, Canada
2023 F150 Lightning Lariat ER
I am currently in the process of having one module replaced. Before it went into the shop Car Scanner was showing 100% for the battery state of health. So I don't think it reliably tells you anything about the health of the HVB.
