Cvh8601
2023 Lightning Lariat
Anyone getting this? Really looking forward to my 500A charging, someday…
Keanen
Keanen
MN
2023 F-150 Lightning
Software Engineering
Not for my 2023
electricpig
Tim
Northwest Arkansas
I have not gotten it on my 23 XLT SR, however I got the fastest DCFC I have ever seen last weekend at 171 kw, which is well above official FORD charge rate for SR. So maybe something was rolled out in the background.
Cvh8601
I had a minute or two above 170 kW at a RAN charger earlier this week, but that was still only 450A, i just started at a high SoC / voltage.
Ohms law, Watts = volts * amps. 170 kW @ 450 A just means our packs are at ~377V. That same pack voltage @ 500A would be ~188 kW
Cvh8601
fair enough! maybe you have that update already then. i think i read on some post or another a rumor of having the pieces of the original 10.3 update repackaged into other updates so maybe you got it!
tearitupsports
Russell
Houston, TX
I just received this update this evening.
Ford F-150 Lightning OTA Software Update 10.3.0 - Powertrain, Battery, Parking Brake IMG_2496
Interesting, this is one that I never got, it was pulled out of distribution before they reached second string.
Jim Lewis
San Antonio, TX
I just got the 10.3.0 Powertrain update when I turned on my truck this evening. It erased my charging location, target charge, and preferred charging times. I removed my vehicle from FordPass and then added it back again. I briefly charged and added those settings back through the truck SYNC screen, set up phone-as-a-key again, but >90 minutes later, the charging settings have yet to reappear in FordPass, which I also updated from the iOS App Store to v5.21.0.
tearitupsports
Russell
Houston, TX
Was your charge cable plugged in when the update occurred?
I didn’t lose any settings but I did the update manually before I plugged in to charge.
richguy82
Richard
2023 Ford Lightning Lariat
I haven’t really had any issues with my truck except for occasional, random parking brake deployments. Maybe this will fix that if I ever get this update.
Jim Lewis
San Antonio, TX
No, I unplugged my charging cable before I allowed the update to run. My settings were cleared from both the truck and FordPass.
Still no settings in FordPass this AM. Time to delete vehicle again, uninstall, reinstall FordPass, etc?
tearitupsports
Russell
Houston, TX
Before resetting everything, I would verify that the app is actually getting proper updates from the truck (or that the truck is updating the cloud server properly). I would turn the truck on, and make sure the appropriate icons (usually wifi symbol and up/down arrow symbol) are on then just refresh the screen in the app first.
For instance this morning my truck is not updating anything. It just shows the cellular bars icon, and according to the app is still waiting to charge (which is the state from about 8:45pm last night). While this is a very common occurrence for me, maybe it happens every so often to others as well.
To be honest it doesn't really matter if the app shows the charge location / times correctly as it only matters what the truck itself is doing.
Are you sure those parking brake deployments are random? If the truck is on a slope it will set it automatically. Time is not my friend and I get more forgetful every day, but I believe it was the '24's that the SW was updated to set the parking brake every time you put the truck in park. The brake will automatically release many times too, more in Drive vs Reverse.
richguy82
Richard
It’s random in my case because it happens maybe 1 out of 10 times I park in my slightly sloped driveway. It doesn’t automatically disengage either. It will still be engaged when I try to depart the next day.
