Add Charge enhanced charge settings
21st Century Truck
Martin
My modules were all updated as of mid-May 2025 and I only have a pending frunk update now (not worth the $50 IMHO)... and on my 2023 XLT with its 12-inch screen, this doesn't (yet) work.
I greatly appreciate the heads-up and the discussion!
02Reaper
GA
2022 Lightning XLT ER
I have a 22 XLT with all of the current OTA updates, Including the Sync version listed on the first page. My 3rd digit was already a 6 and the 4th digit was a 4. Changing the 4th digit to a six did absolutely nothing on my truck. I guess I am missing the other updates that have to be done via FDRS.
PJnc284
Garner, NC
Not missing much. Only upside atm is having the charging speed on the center screen without having to jump through hoops to get it on the IPC like 24+.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
It’s going to be a bummer if our 22’ and 23’ trucks can’t do this because of PCM module hardware that only 24’ and above have.
02Reaper
GA
I was hoping I would at least see the charging rate on that screen, but It didn't change a single thing at all. The screen looked and preformed the exact same as before changing the value. I could care less at this point about limiting DC Fast Charging, but I would love the option of limiting AC Charging on the truck side.
LazyElectrons
Tim
22 Lightning Lariat ER, 17 Exploder Sport
I changed my 4 to a 6 and it appears I have enabled these features. I haven’t done any testing other than seeing the charging rate.
priceb
Price
Western North Carolina
2023 F150 Lightning XLT
College Instructor
Thank you for providing this information for us to try. I can confirm that this doesn't yet work on my XLT SR. All relevant modules were updated in mid April. I have left it enabled in preparation for whatever future update might provide the missing piece.
Let us know if you lose your charge locations and/or if resets your charge limits.
Vancouver, Canada
2023 F150 Lightning Lariat ER
Okay I tried this out. 23 Lariat ER that just had two battery modules replaced a week ago and the EV Tech told me that he updated every module and everthing that could be updated was. Made the zero a two in Forscan. It appeared on my screen and I like the look! I think you could use it daily but it is buggy when it comes to the global charge settings. Any changes to amperage etc will not stick. The best thing to do is press reset in that screen exit and save. Everything will be saved to max even though it doesn't look like it on the main screen. The charge location scheduling and percentage saved just fine. Another bug is that it recommends 100% as the optimal charge level.
Ford F-150 Lightning Add Charge enhanced charge settings 20250612_100859
Jesse-Infotainment
2024 F150 Lightning Platinum
Thank You for testing it. That sounds how mine behaved. I played with it some last night
I could turn the location off in the truck and it was off in Fordpass as well. The issue was I couldnt turn the charging location back on in Fordpass only the truck.
Thanks Jesse. So at this time, this appears to only work on 24's. @PJnc284 has a 23 fully updated and made the edited change (changed xxx4 to xxx6). His results were mixed. Settings wouldn't hold across charge cycles.
My modules are out of date, so if any other 22-23' Lariats and above want to try, please post here.
APIM 7D0-10-4 xxx*-xxxx-xx change 0 to 2, 4 to 6 (22-23's) . . OR . . change 8 to A, C to E (24's).
I apologize if this is already documented, but what is the 24 IPC firmware update to show charging speed on the instrument cluster?
There has been other confirmation, but I'll add - another '22 Lariat fully updated - APIM 24127 (there is newer in the wild but not available for my truck).
I made the change noted for 7D0-10-4 I had a 4 and changed it to a 6. New menus showed up. Have not played with the settings much. I'm only plugged in to 110. I'll plug in to the 48 amp Tesla charger tomorrow and see if I have any other results, likely not.
Ford F-150 Lightning Add Charge enhanced charge settings IMG_9017
Bitterbrush
Twisp, WA
2007 F-150, 2015 Explorer, 2023 Lightning LariatER
Pilot
I did this a couple weeks ago on my ‘23 Lariat ER. Everything worked out fine, I thought, but the charge rate data fields don’t work. ?
PJnc284
Garner, NC
Stopped and verified that it also showed speed when dc charging. Would be nice if it showed amperage and if station limited but will tide me over for now without jumping through hoops to get charging speed on the IPC.
Ford F-150 Lightning Add Charge enhanced charge settings 1000010465
02Reaper
GA
So I updated all of my modules in my 22 xlt last night via FDRS. I already had the 6 as the 3rd character so I changed the 4th character from 4 to 6 a week or so ago. That change was still present. Still nothing on my xlt screen. I’m curious how Jesse got it to show on his 12” screen on the bench as I am up to date on everything except for the bcm at this point and all of my settings are correct.
408sbfmustang
San Jose, CA
2021 Ford F150 XLT 3.5 Sport
Tech
If I have sync version 25094 with this work?
Building date 12/23 Flash
