VirtualTed
- First Name
- Ted
- Jun 11, 2022
- Las Vegas, NV
- 2022 Lariat LR
- Occupation
- Software Development
That's a great idea. I have only taken it to about 20% once and I took it to 100% about 4 months ago on a short trip, and then immediately began the drive. I do live in Las Vegas, and it started hitting 105F a day here, so that may have had an effect too.Could be BMS drifting is an issue. Basically without going down to near zero, or 100% the BMS can lose track of actual. The SOH you are seeing is what the BMS thinks, and that may not be entirely accurate. Many people charge to 100% occasionally for this reason. I have read that the remedy is to run it to near zero, then in one continuous charge to 100% (meaning it shuts off on its own). This also has the effect of leveling all cells, meaning evenly charged which can throw off SOH calculations as well. Lastly, it's not just battery usage, it's also age of the battery pack, and environment, especially very high temps. But of course you may have a weak cell or two.
Try deep discharge to absolute full charge. Just keep it either end for as little time as possible.
I also recently had a couple recalls done (front sensors and front hatch control module on May 5). The timing is suspicious...
