Size H3 starting battery replacements?
Does the Lightning need to be programmed to tell it you put in a new 12V? I know on some cars it's recommended since it optimizes charging based on age degradation.
I said "need" to be programmed, I know it likely doesn't really matter. Just wondering if the truck has the capability of being told it has a new LVB.
Yes it is recommended that you clear the learned values from the BMS associated with the old battery. You can do that with FDRS or follow this procedure:
  1. Press the start button without stepping on the brake (Accessory mode).
  2. Note red Battery icon will come on in the instrument panel.
  3. Flash the highbeams with the stalk 5 times.
  4. Press the brake pedal 3 times.
  5. Check the red battery icon on the instrument panel to see that it flashes three times.
  6. Press the start button again to turn the truck off.
To check, turn truck back on and use CarScanner to see value of 12V battery reset. If done correctly, you will see 0 days.
Ford F-150 Lightning Size H3 starting battery replacements? 1754584657546-es
tls
New York
2022 Lightning
Am I correct in my recollection that the BMS reset procedure should only be run with a freshly charged battery connected?
The service manual just says to run the procedure after the new battery is connected - nothing about charging first. Probably an old wives (technicians) tale to charge first.
It also recommends doing an initialization on each of the one-touch windows. Also anytime the battery is disconnected you need to close frunk manually and do a frunk initialization: "manually move the hood downward until the striker reaches the secondary position. The FHCM will complete an automatic cinching operation."
In other words, lower it slowly until it catches and closes the rest of the way on its own. Don't slam it shut.
tls
New York
2022 Lightning
I don't think ensuring any new battery connected is fully charged is without rationale - the BMS has to learn a number of parameters of the battery and it should be much more efficient if it starts at a known state of charge. But, if the service manual doesn't say to do it - OK.
Yeah I think its unnecessary, the BMS will figure it out. And think of the number of NTBs, AutoZones, O'Reilly, etc. (even dealers) replacing batteries in their bays or heck, their parking lots. They aren't charging them first and probably aren't even resetting the BMS.
Rice_classic
Rice
2023 F150 lightning lariat ER
I would also recommend that anyone buying a new 12v battery and have the older BMS, to spend the $20 on the updated p/n BMS.
I have a ‘23 and a dashcam with a shutoff at 12.5v and often got a notification for 12v being low and could get ota updates. With the new BMS, I have zero battery notifications and ota updates come through.
Shmoe
2024 F-150 Lightning Lariat, 2025 Rivian R1S, Sold-2020 Tesla Model 3 SR+
How would we know if we have this? '24 Lariat here.
I believe us 2022 were as well. There was a TSB/recall done. There’s a thread on this if i recall.
Correct. 2022s and some 2023s.
ElectrifyingMe25
Trav
F150 Lightning, XLT, 2023
Looking to replace my 12V starting battery as it's now 3 years old and has been discharged significantly a few times. The cheapest I can find the Motorcraft replacement is about $215 shipped. I see there are 3rd-party options that all cost more, but then I see a Toyota option (they stock it for the Prius C) in the $150-$180 range.
Not interested in lithium alternatives. I've seen a few tear-downs of those which scared me. Also, my truck is outside in the cold quite a bit in the winter and an LFP starting battery seems like a poor choice for that reason alone.
What are people using for their starting battery replacements, and am I finding the best prices? $200 for a battery of this capacity seems relatively obnoxious, but then again, it's clearly not a common size.
AutoZone sells a replacement.
Ford F-150 Lightning Size H3 starting battery replacements? Screenshot_20250923_175343_DuckDuckGo
Ford F-150 Lightning Size H3 starting battery replacements? Screenshot_20250923_175358_DuckDuckGo
spamming threads
Check costco. I think they should be around $110-130.
Which battery did you get at Costco? The one nearest me carries Interstate batteries and they can't find a cross reference and the Lightning isn't listed in their system.. I just looked through the Interstate web site and they have an H3, but well over $200.
MichaelCA
'22 Lighting ER, '22 Tesla Model 3, '16 Mustang GT
I didn't go to Costco for the Lightning yet, I didn't realize the H3 battery type seems to be rather low volume/unique. I was speaking based on prior experiences with my other cars.
https://www.rockauto.com/en/parts/motorcraft,bhagmh3,battery,2476
Found the Motorcraft H3 on RockAuto for $102.99(includes core charge) + shipping.
