B177y
- First Name
- Bill
- Jul 16, 2024
- Olympic Peninsula, WA
- '24 Pro SSV ER Max Tow, '23 MME Premium, '20 Bolt
When you use your trickle charger are you attaching it to the jump posts under the passenger side frunk trim or directly to the battery posts at the center-rear of the frunk?I'm using this tester and I've been testing it at various times throughout the day. I charge about 1x per week, and I don't think I've tested after charging it. I'm charging tonight, so I can check it in the morning. Thanks.
If you attach the charger directly to the battery, you could bypass the BMS and you'll get all sorts of weird 12 volt issues.
You should be using the jumper posts to charge. If you are already doing that, then I agree with the other suggestions that you need to get a load test and possibly new 12 volt battery.
