chuck27p
- First Name
- Chuck
- Mar 28, 2023
- Orange County, CA
- 2023 F150 Lightning Platinum Black
I am attaching the trickle charger to the battery directly (inside the frunk, center, behind sliding panel). I didn't know there are jump posts. Just looked it up and found it in this video.When you use your trickle charger are you attaching it to the jump posts under the passenger side frunk trim or directly to the battery posts at the center-rear of the frunk?
If you attach the charger directly to the battery, you could bypass the BMS and you'll get all sorts of weird 12 volt issues.
You should be using the jumper posts to charge. If you are already doing that, then I agree with the other suggestions that you need to get a load test and possibly new 12 volt battery.
I have trickle charged twice to the battery directly. The last one was about a week ago. Should I try again to trickle charge with the jump posts instead? Sounds like it. Thank you for the help.
