mr.Magoo
While the heater element itself is roughly 10-12kW (think max energy I've seen it use is 10.8kW), by no means does it use 10kWh to heat the battery. (at least not in the beginning and not even thoughout the charge cycle unless it's pretty cold)I did... about 10kWh for a ER pack is what I am reading which is about 8% ish of a charge.
As you can see from the below charge cycle from ~37% to 90% it's only using the heater (shaded green block in the bottom half) during the first 7min to get the battery over 33.8F when it closes the valve (orange line in the bottom chart) that directs the coolant to the battery.
So 7min * 9kW (on average) is only 1.05kWh
I have no idea why they're waiting a full two hours after before they enter some sort of repeatable thermal management mode.
2nd chart is from last year to show the same type of behaviour, so it's nothing new.
