capt_ramius
Sean
St. Louis
2022 XLT 312A
I successfully sent power back into my home from the 240V/30A Pro Power outlet in the bed, the truck did not trip. I had an electrician install a Reliance LinkX neutral-switching transfer switch for GFCI generators, moved most of my home’s essential circuits into the transfer switch… tested it out by connecting my Lightning to the inlet, cut off utility power, manually turned on the transfer switch, and it worked like a charm!
This is basically the simplest and cheapest solution to power your house within code using the truck’s 240V bed outlet… no “suicide cord” and no questionable ground or neutral switch on the inlet. I won’t say what the cost (since there are so many variables to each installation) but it was a fraction of the reported cost of the Intelligent Backup Power system.
Please note: You have to use a transfer switch specifically designed for GFCI (neutral-bonded) generators. A normal transfer switch for backup generators will not work because of the neutral-switching issue.
30 amp generator cord connected to the Lightning:
Ford F-150 Lightning PRO POWER OUTLET SUCCESS! Powering My House With Transfer Switch for GFCI Generators AF596667-F15F-4D03-88BC-06403F46ACBC
Generator cord inlet’ed to the transfer switch:
Ford F-150 Lightning PRO POWER OUTLET SUCCESS! Powering My House With Transfer Switch for GFCI Generators 3EAE3556-075E-4F45-AB02-7A2F945FD48D
The Reliance neutral-switching transfer stitch (it switches off one of the neutrals in the loop so you don’t get the fault in the truck):
Ford F-150 Lightning PRO POWER OUTLET SUCCESS! Powering My House With Transfer Switch for GFCI Generators 182C948A-3413-453E-9E90-BE85CB370B34
Pro Power Onboard powering the circuits in the transfer switch… only drew about 500W:
Ford F-150 Lightning PRO POWER OUTLET SUCCESS! Powering My House With Transfer Switch for GFCI Generators 139A3F17-4B69-4145-9AAA-A635EC40388F
Parts list:
  • 30 amp L14-30P/R generator cord
  • 30 amp generator inlet
  • Reliance XRK0303D 30 amp transfer switch for GFCI generators (updated version of the XRC3030D), see page 50 of the Reliance parts catalog https://api.reliancecontrols.com/media/DAFD6723826113254930/DAFL6723827471620578.pdf. You can order through local electric supplier.
    • Generac HomeLink 6852 is an equivalent 30 amp neutral-switching transfer switch for GFCI generators (can order through electric supplier, big box home improvement stores, or online).
  • A licensed, insured electrician to install
(I am not an electrician and this post is not advice or a “how to”… just sharing what I did, install at your own risk. Please consult a licensed electrician if you’d like to consider this option.)
mmcguirk
MD USA
2022 Lightning Pro SR
Pilot - retired
Has anybody found a "just the switch" solution for those of us who already have an "essentials" subpanel? IOW, I don't need the "10 branch circuit spaces", already have them... just need the three pole switch.
capt_ramius
capt_ramius
Sean
St. Louis
2022 XLT 312A
Yes, see:
… but the Siemens three pole double throw disconnect in that video is $2,000 just for the part. Might be more reasonable to just replace your “normal” transfer switch with a neutral-switching transfer switch (that also work for normal generators, so you can use one of those or your truck).
chillaban
2022 F-150 Lightning Lariat
Sweet!
Just a noob question: despite the generator outputting 30A, is there a limit to how many “essential circuits” you can have? Unfortunately in my house I feel like our “essentials” are scattered over a bunch of different circuits despite us not using more than 7kW at any given time.
awilli1010
SE Michigan
Sweet!
You can power as many circuits as you want. But you can only draw 30 amps total.
capt_ramius
capt_ramius
Sean
St. Louis
2022 XLT 312A
https://www.amazon.com/gp/product/B0743BQDT4/ref=ox_sc_saved_title_8?smid=A35393ZKSQP6NY&psc=1
Would this work? I thought I saw where another member used this to power his home.
Not exactly the same. My inlet is connected to the neutral switching transfer switch, which powers the circuits in my house. The product you have linked just powers those six outlets… so you’d have to run extension cords from those outlets to the individual items/lights/appliances. Other than more convenient placement, I don’t see any advantage to that “through the wall” kit compared to just running extension cords directly to/from the outlets in the truck bed and mega power frunk.
Nice setup!!
wiffleballpractice
Georgia, USA
Lightning Lariat SR, XC40 Recharge, XC90, Cayman
Pretend Electrical Engineer
Glad you were able to get this done before Reliance temporarily stopped selling those panels.
Ford F-150 Lightning PRO POWER OUTLET SUCCESS! Powering My House With Transfer Switch for GFCI Generators 1671481955156
capt_ramius
capt_ramius
Sean
St. Louis
2022 XLT 312A
Aspesi4
Boston
Volt
Also, this product is only rated up to 30A. The real solution is a 200A, 3P switch that's economical.
