P-38
You could take modules and build a 32Kwh pack and then run the EverDrive charge while driving.No - Each module is somewhere in the range of 32V to 44V each. You need multiple of these modules (9) in series to get to ~350V - 400V range. You can't just take a single module out and "make it work".
You would not be easily able to tie the battery direct to the DC bus because of the above mentioned voltage difference.
