Electrify America?
Hunter
Hunter
TN
F150 Lightning
Did Ford and Electrify America have a falling out? When I bought my truck, it almost always routed me to Electrify America charges on trips. This was likely due to their Oval partnership, but in truth, they really were the best chargers for trips. Now going on the exact same routes, it's like my truck pretends Electrify America chargers don't exist and will route me to worse and slower chargers when there is an Electrify America supercharger that is clearly the better option. Has anyone else noticed this?
davehu
hot springs, AR
Routing from Ford's navigation is more likely a software issue. A Tesla charger that I had used only a few weeks ago (with adaptor) right now doesn't even show up in either Fords navigation or Charge Assist! It was there when I made the trip and it does show up in Ford Pass. Ford has a long way to go with software. Use ABRP
Hunter
Hunter
TN
F150 Lightning
I use ABPR, the free version. Have you tried the subscription one? And if so, how is the interface and how accurate is it? I have thought about trying it, but haven't talked to anyone that's used the pay version.
Danface
Dan
Central Mass
2023 Lightning XLT
Download all of the apps and compare. I wish one of them would allow filtering or sorting by $/kWh. I know the Fed data for that is "free formatted" so my best guess is that' may be a contributing factor.
you can also limit searches for certain 'speeds' of stations, such as tapping the 'Ultra Fast Only' speed tab, which EA typically qualifies for... at least on the FordPassApp.
davehu
hot springs, AR
I haven't tried it. I really don't travel long enough distances but I plan carefully before leaving home
Free version works fine.
Firn
23 Pro ER
ABRP is a good planning tool but a mediocre navigation app. I have started plotting the next charger into Google maps and just using that. The major feature I DO like with ABRP (at least on the Nav side) is the current charge percent. It tracks what Soc it thinks you should be at and you can compare that against actual to see if you are going to get there under the expected arrival percentage.
Ford nav is trash. I MIGHT have some faith but since it randomly locks up I can never count on it (I'm on old software however)
VAF84
Central Texas
2024 Sierra EV Denali
Consultant
Yea, don't depend on the Ford routing. On longer trips I'll run ABRP on one device and then either Apple/Google maps via CarPlay on the other. Apple has started to become a pain with EV routing as well, so as others have mentioned I navigate directly to the ABRP stop on the vehicle/CarPlay nav, and use the suggested charge time on ABRP before navigating to the next leg shown on ABRP.
The bigger issue is that my Ford won't prioritize Tesla chargers for me. I prioritize them because they're considerably less expensive, more conveniently placed, and to date 100% reliable. In fact, I don't think it will ever route me to a Tesla charger. Maybe because I haven't received my Ford adapter and I've been using my A2Z one. At least ABRP allows me to prioritize Tesla for my stops.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Has anyone noticed network improvements with EA? Their press release stated they expect 30% growth this year. In 2024 they derated some stations to 150 or even 50 KW for hardware reliability and subsequent replacement. Along with that, some of the sites around me have improved plugshare scores. Whats your experience?
I haven't used the local EA in a while, but looking at plugshare reviews, I see that the same two troublesome terminals #2 & #4 are still getting negative reviews, while the working terminals are only maxing to 150KW, which I seldom got to see when I charged there.
My last DCFC was at a Tesla site up the road from the EA, great performance and cheaper price.
It is very location dependent. EA has replaced a lot of the older unreliable locations (but not all). In some locations, brand new equipment has issues. In others, they are good as gold.
That's why you need to use ABRP and PlugShare to plan a trip. Look at the reviews and see what's going on. In some cases, you may have choices (EA or Tesla). In others, you have no options (EA across Wyoming, or Nevada).
SilverLight
Brent
2024 F150 Lightning Lariat
I believe the in-car nav hasn't been updated yet to recognize the Tesla chargers as a useable option, so you would need to look up the address and navigate to that.
jimfigler
Orchard park, NY
anyone know a way to check balance of free 250? I looked on ford.com account, the app and EA app and cant find it
Piquette
Trent
New Hampshire
2022 Lightning Lariat
My issue with EA is the steel barrier poles they put up next to their chargers. Last September at the Erie, PA, the wind caught the driver side door as I was getting out and slammed it into one of the posts resulting in a half dollar size dent. Since then I have tried to avoid EA charging stations to prevent further damage to the truck.
