What is your SOH, Mileage, and how do you use your Battery?
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Software Development
Regarding my sudden drop from 100% SOH to 95.5% in the last couple months, I decided to drain the battery to ~5% and then charge to 100% to help reset the BMS stats as suggested earlier in this thread. I'll try to be as succinct as possible in what happened next.
06/16 4:00pm - Drained battery to 2.5% by driving around. I let the truck sit for 5 hours and then started charging at 32A with charge limit to 100%. Recorded the following stats at that time...
HVB SOC - 6.09%
HVB SOC Display -2.5%
HVB SOH - 95.5%
HVB AGE - 34.89 Months
HVB SOC module variation - 11.09%
HVB Min Module voltage - 3.3V
HVB Avg Module voltage - 3.56V
HVB Voltage Module variation - .27V
06/17 8:00am - Woke up. Currently at 74% and still charging. Says it should be done at 1:30pm.
06/17 9:00am - Phone says charge completed at 100%. I go out to truck, turn it on and it shows 100% on initial screen, but when I get to the standard dash, it drops down to 77% w/ 255 miles range. Battery says it's at 100F and truck is sitting quietly with ambient temp at 87F. (I expect to hear cooling fans or something). I unplug/plug in charger and tell it to start charging. Phone says it is charging, but no light is on at plug and the "charging noise" is not present. I turn on the truck and immediately hear the familiar hum form under the hood area, but no cooling fans or anything else. I turn off the truck and humming stops, but still no charging and no light at charge port.
At this point, I'm trying to figure out why it isn't charging, and why the battery is so hot (and not cooling it down). I decide to unplug the 12V battery for 10 min. to reboot it all. Once that is completed, I turn on the truck like I'm going to drive it and set it to sport mode to enable "extra cooling". All the cooling systems come on and after 20 minutes or so of just letting it sit there with every fan blasting away, it brings the battery down to 86F at which point the truck goes silent. (During this time, I also notice that the tire pressure is 146PSI on all 4 tires in APP. On display, it just shows dashes for each tire.)
So, with the battery cooled down I plug the truck back in to the charger, and tell it I want to go to 100%. After 20 minutes, display still shows 76% SOC and "Charging to 100%" on dash, but there is no charging happening and the 5 little charging lights are dark. Ford charger seems fine, with blue light showing.
So I guess I should probably take it in, but I would like to hear any thoughts you guys have before I do so. I should also mention again that I got a couple recall updates done before all of this started happening which were 24P24 (Front Hatch Control Module), and 24B56 (Inoperative Front Parking Sensors - Software Update Image Processing Module A).
Thanks!
-T
Needs to be driven a few hundred feet to get the pressure sensors reporting correct values
electricpig
Tim
Northwest Arkansas
Doesn't sound good to me
I'm in no way a.battery expert, but
your 11% variation in SOC module variation, followed by not fully charging says you me that you have a failing module. Other have reported the 100% charge immediately reducing to the approx 75% to find out they had a bad module in the battery pack.
Your service department you use should be able to determine if this is the case quickly.
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Sounds good. I appreciate all the advice on this forum. Going to make an appointment now and will let everyone know how it turns out.
Maxx
Maxx
let the truck sit for at least 5 hours,
I have heard this a lot. How much of it is for battery to cool down and how much of it is for cell balancing? Is it really necessary for this process? Lets say you are doing this in winter and battery temperature is not an issue. Wouldn't cells balance when they reach 100% SOC anyway? Why would you keep the battery at that low SOC for five additional hours if it does not help the BMS in calibrating? I appreciate it if you can spell out why that 5 hour rest is helpful here and why the benefit of it outweighs the damage to the battery for sitting at low SOC.
GoodSam
Good
occupying space
Another thread with evidently a Ford tech message SSM 53208 about dropping power %, noting that there might be a bad cell:
https://www.f150lightningforum.com/...pack-soc-unable-to-reach-target-charge.23075/
Your battery module variation is huge. What is your Build Date (month/year on driver's door sticker) and mileage for your 2022 Lariat ER?
See if you are affected by this Safety Recall 25S18, where you might qualify for a full pack replacement! Check your Vin at ford.com.
https://www.f150lightningforum.com/forum/threads/hv-battery-electrode-misalignment.25331/
But still I think if you have a bad cell in one of the 9 modules, you will be covered for that replacement since you are less than 8 years and 100K miles.
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Build date is July 22 and I've got barely 30k miles now. I did check for the recall but my truck isn't included, so I'm guessing just a bad module. However, I might bring up this issue anyway to see if they can give me a double-check on the electrode misalignment thing. I would not be sad to get a completely new battery. :)
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
I’ve heard it a few times, but there is a guy with the username “Mach-Lee” on the MachE forum, who has pretty extensive experience with EV batteries. He posted a “HV Calibration Procedure” blurb back in Nov 2022 that’s applicable to all EVs, and in that post, he states: “The rest periods at low and high SOC are very important to wait for so the BMS has time to read all the cell voltages accurately.”
https://www.macheforum.com/site/threads/hv-battery-calibration-procedure.23815/
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
"It's important to understand that performing a BMS calibration does not physically restore lost battery capacity (which is gone forever), it merely updates the computer estimate of capacity only so that it is more accurate. The battery has whatever intrinsic capacity is currently has regardless of what anyone says, does, or thinks (including the GOM), so you could argue it's best to not think about BMS drift and just go about life unless you are concerned with accuracy."
WaterboyNorCal
Erik
NorCal
Nunya business ;)
Yes, of course. It’s relevant to this discussion however because people are putting a lot of stock in the ‘State of Health’ data point that is produced by the BMS. That estimate can be quite misleading due to drift/calibration issues.
Additionally, if you ever road trip and need to use the bottom 10% of the battery pack, I would suggest that BMS accuracy is rather important. Nobody wants to be at 6% indicated SOC and a few miles away from the nearest DCFC and find out that BMS drift is a real thing.
Maxx
Maxx
when year nine arrives, at the edge of 70% there could be a lot of warranty claims due to this reading.
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
So, as a follow-up to my SOH dropping from 100% to 95.5% over the course of 8-10 weeks...
The truck is now at the dealership and after a day of diagnosis, they said it needs two "battery arrays", which I assume means battery modules. Likely 3-4 days to get it all put back together and back in my driveway.
-T
electricpig
Tim
Northwest Arkansas
Sucks your having module failure, but at te same time you were lucky to find it before it became a big problem. Didn't get stranded, not stuck in the dessert atud afternoon, didn't hit at the worst time etc. Your monitoring actually caught a issue before failure. Best outcome. I will certainly continue to monitor my battery pack.
Hope you get it back quickly. Thanks for keeping us updated.
WaterboyNorCal
Erik
NorCal
Nunya business ;)
Yep. Although it sucks that OP has been dealing with this issue and now has his truck in the shop waiting for a module replacement, better that it happened now than at 120k miles when he would be paying out of pocket for two replacement modules and the associated labor costs.
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Yeah, sucks not to have the truck for a week, but I do count it as a positive to be getting a couple new modules installed. While I don't like doing it normally, I think placing some stress on the battery (running down to less than 5% and up to 100%) before I get out of warranty at 8 years/100k miles might be a good idea. Might find a couple more on the verge of needing replacement.
