VirtualTed
- First Name
- Ted
- Jun 11, 2022
- Las Vegas, NV
- 2022 Lariat LR
- Occupation
- Software Development
Regarding my sudden drop from 100% SOH to 95.5% in the last couple months, I decided to drain the battery to ~5% and then charge to 100% to help reset the BMS stats as suggested earlier in this thread. I'll try to be as succinct as possible in what happened next.
06/16 4:00pm - Drained battery to 2.5% by driving around. I let the truck sit for 5 hours and then started charging at 32A with charge limit to 100%. Recorded the following stats at that time...
HVB SOC - 6.09%
HVB SOC Display -2.5%
HVB SOH - 95.5%
HVB AGE - 34.89 Months
HVB SOC module variation - 11.09%
HVB Min Module voltage - 3.3V
HVB Avg Module voltage - 3.56V
HVB Voltage Module variation - .27V
06/17 8:00am - Woke up. Currently at 74% and still charging. Says it should be done at 1:30pm.
06/17 9:00am - Phone says charge completed at 100%. I go out to truck, turn it on and it shows 100% on initial screen, but when I get to the standard dash, it drops down to 77% w/ 255 miles range. Battery says it's at 100F and truck is sitting quietly with ambient temp at 87F. (I expect to hear cooling fans or something). I unplug/plug in charger and tell it to start charging. Phone says it is charging, but no light is on at plug and the "charging noise" is not present. I turn on the truck and immediately hear the familiar hum form under the hood area, but no cooling fans or anything else. I turn off the truck and humming stops, but still no charging and no light at charge port.
At this point, I'm trying to figure out why it isn't charging, and why the battery is so hot (and not cooling it down). I decide to unplug the 12V battery for 10 min. to reboot it all. Once that is completed, I turn on the truck like I'm going to drive it and set it to sport mode to enable "extra cooling". All the cooling systems come on and after 20 minutes or so of just letting it sit there with every fan blasting away, it brings the battery down to 86F at which point the truck goes silent. (During this time, I also notice that the tire pressure is 146PSI on all 4 tires in APP. On display, it just shows dashes for each tire.)
So, with the battery cooled down I plug the truck back in to the charger, and tell it I want to go to 100%. After 20 minutes, display still shows 76% SOC and "Charging to 100%" on dash, but there is no charging happening and the 5 little charging lights are dark. Ford charger seems fine, with blue light showing.
So I guess I should probably take it in, but I would like to hear any thoughts you guys have before I do so. I should also mention again that I got a couple recall updates done before all of this started happening which were 24P24 (Front Hatch Control Module), and 24B56 (Inoperative Front Parking Sensors - Software Update Image Processing Module A).
Thanks!
-T
HVB SOC - 6.09%
HVB SOH - 95.5%
Thanks!
-T
