- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
it has begun:
Battery Pack MODULE Replacement: '22 Pro SR @ 62,000 miles
history:
- 62,000 miles, towing camper 1/2 of those miles, with nary any issue before now... 3+ years, so far... and lovin' it : )
- last week, suddenly the truck would not take a Level 2 240v 30amp Charge, at home, as it has effortlessly for the first 3 years
- red ring
- using the Ford Mobile EVSE on either 240v or 120v adapters - same outcome: red ring.
- driving the truck was not any issue
- drove to a local DC Fast Charger, Tesla 350kw brand new 'Other EV' Blue oval network capable with Plug-N-Charge - same outcome: red ring.
- this exceptional EV truck has graced the presence of a Ford dealer only twice, before now: tire rotation/30k mile 'checkup'(all good), and later 'grease-leakage' from the driver rear short drive axle, from the tire-side boot. Ford replaced at no cost, under 'Electric Powertrain Warranty', at 40,000 miles.
- Local FORD Dealer looked online at the truck's Software/Electronic alerts and feedback, just by entering the VIN#
- one alert was "Powertrain Malfunction / Reduced Power", which I've seen before, but never revealed itself as any long-term issue, generally resolved at the next ON/OFF cycle. The 12v battery level was excellent, although I had also tried to reset the NEGATIVE terminal as part of my 'reboot' process when this red-ring charging issue first happened. I had also put a 12v charger on the small battery for a while, just to make sure it had a reasonable SOC level. I had also already checked for dealers who had this battery in stock, thinking that this issue might only be a 'low' 12v battery.
- another notification on the Dealer's screen showed something like "Hybrid/BEV Battery" issue, which is likely a tip-off of a cell not holding it's charge, or voltage level.
- they kept the truck for a tech to start some deeper diagnosis
- the next day, I got a call that the diagnosis showed that one of the battery pack modules needed to be replaced, per Ford. Not necessarily what I wanted, or expected, to hear, but if that's what it takes to resolve the charging issue - o.k., and under the extensive 10yr/80,000 mile Electric Powertrain Warranty'.
.... they have received the replacement MODULE, in a crate, and have started the replacement process: will update when completed, today or tomorrow...
history:
- red ring
